RE: ST2300 Testing and Experimenting
Boex:
Dispite all the great info in this thread, my G2300 would deadstick anywhere on the throttle range. I did all of numbers 1 to 6 and gallons of various nitro levels, various plugs etc. BUT, I didn't try #4 (onboard glow) till last! Perry carb, pump etc. seemed to make the engine run smoother across throttle but it would still dead stick frequently and unpredictably. After spending a lot of money on all these trys I finally installed a switch and a 4500mah nimh C cell (#4). The engine runs like a champ now!
I would recommend you try #4 FIRST before you try anything else, it is the cheapest to try ( under $10 for switch and battery).
Thanks to everyone for all the great info on this thread. It helped a lot. I have a variety of non OS engines some are the cheapest around. But I've never had a problem getting one to run reasonably until the 2300. I spent just too much time and money on the this guy. I'm not a Super Tigre fan anymore!
Cheers for now!
