RE: Extreme Flight RC Yak 54 - 74 inch!
Your was without pants & spinner too?
Here's couple "all ups reported on the Combo thread"
First yours STG:
E.F. 74” Yak/ Brillelli 46 combo
HT 5625’s &Airwild 1.5” arms in the tail
HT 5645 on rudder &Airwild 3.0 arm on rudder
HT 5625’s in wing & Hitech 1.25 HD arms on wings
Futaba 3004 on throttle (might go to HT425)
Four 12” twisted servo extensions
Sullivan graphite Nyrod # S584 with 2/56 ball links on throttle cable
Smart-Fly Ignition Cutoff
Fromeco Failsafe Heavy Duty Slider Charge Switch
Cheap battery packs 1500mah 2/3a 6V battery pack on receiver and 750ma 2/3aa on ignition (6oz together)
Dubro 10oz gas tank
Upsized tail wheel (from Mini 3D main gear) + 3/16oz
KAVAN 4” AIR TIRES with chrome hubs (+2.5oz pair)
Weight RTF will be 12pounds 4.5oz dry
____________________
My Yak54 with the brillelli 46gt.
It weighs 13lbs, it will be less when i get the new muffler.
B&B gas tank
NX 20x8 prop
Hitec 5985 on the rudder
Hitec 5645's on the elevator's and aileron's
Air Wild aluminum servo arm's
2700 6v battery
Chris Hinson:
Brillelli 40cc powered Yak
12 lbs 2 oz.
Hitec 5645s on ailerons and elevators
5985 on rudder
standard HS-425 servo on throttle
Fromeco 2400s on ignition and flight pack.
Mejzlick 20x7.
