RE: E-FLITE BLADE CP PRO
thanks for your fast replys the main motor is getting pretty hot they are all new motors.the batt. are brand new and i tryed a friends thunder power 1320 charger on his charger and it did the same thing.the head feels pretty smooth and most parts are new but i did not lube the shaft i lubed the orings where the spindle goes though .
whats the best way to center the swash plate? or how long do you have your rods?
main gear is clear. i will try lubing the main shaft and the gear mess and see what happens
thank
Tom
