RCU Forums - View Single Post - Is a 6 channel reciever enough?
Old 04-03-2007 | 08:59 PM
RCKen's Avatar
RCKen
RCU Forum Manager/Admin
My Feedback: (9)
Default RE: Is a 6 channel reciever enough?
Yes, a 6 channel receiver is plenty for what you want to do. You will/can run the aileron servos from one channel in the receiver, plug a Y-harness into the aileron channel on the receiver and then both of the aileron servos will plug into each end of the Y-harness. With this setup you only need 4 channels of the receiver. Even if you use a seperate channel for each aileron (by using a computer radio) you will still have enough channels on the receiver because you only need 5 channels for the servos.
Hope this helps
Ken
