RCU Forums - View Single Post - gas fuel with glo plug no ignition
Old 04-04-2007 | 02:11 AM
  #1181
av8tor1977's Avatar
av8tor1977
Default RE: gas fuel with glo plug no ignition
So far I've done Echo 23.6cc engines, Homelite 25 & 30cc engines, a Ryobi 31cc, and a Poulan 42cc on Gas/Glow. At some point in all our beginning experiments, Aeronut reported some detonation in a Ryobi 31cc. We switched to using Premium in the gas part of the mix, and the problem went away. I just now use premium in all my engines. My Poulan 42cc is the only one that has a rpm drop when the glow plug power is removed, suggesting that it could use a touch more compression to be optimal. (Or a touch more nitro in the glow part of the mix.)
But as always, experimenting is great and often leads to useful new information.
Good luck,
AV8TOR
