RE: Super Tune Your Super Vee 27
A few Silly questions guys: Can you over grease the drive shaft? Should you attempt to remove the remainder of the old grease out of the shaft tube before you re-grease the shaft? If so, how? I'm asking because I have noticed higher battery and motor temps after I perform this maintenance. Also, there is always some grease left over in the shaft tube...it's just black in color. Also, the teflon tube inside the shaft tube...does it need to be replaced periodically...if so...where do I get one?? Thanks!!!
