ORIGINAL: acrored
ravill, be carefull with the elevator before your maiden, if u have the elevator neutral, i mind, parallel to the fuse flight line move your elev trim all the way down (nose up in flight) and this have to be your new neutral position, if u fly with the elevators parallel to the fly line the elev trim wont be enought, take a look at the picture, that should be your neutral position for the first flight, take care...
David S, is this what you found as well?
