RCU Forums - View Single Post - EagleTree Data Logger results
Old 04-04-2007 | 08:30 PM
woodie's Avatar
woodie
Default RE: EagleTree Data Logger results
ORIGINAL: woodie
ORIGINAL: OhD
Don,
You probably need to look at the data in Excel. You will probably see these are not spikes. When you compress the time scale normal throttle changes might look like spikes.
Nothing new to report from down here. Hope to finish the kitchen and get back to fun stuff. I was hoping to get my Dualsky in the air by 1 April but it isn't looking good.
Jim O
Jim,
Good idea, I did scan thru the fdr file and the graphing software compresses details a bit. I have found I am getting spikes from the controller tho so I guess it is time for it to make a trip to the factory. If I throttle up slowly, I can hear the hesitations so I will go back to my Jeti 90, good old bullet proof controller.....
Don
I ran with a standard Jeti controller today and it was much smoother, no hesitations and the Eagle Tree didn't show the jagged lines on throttle up. Problem solved.....
Good ole std Jeti controller!!!
Don
