RCU Forums - View Single Post - gas fuel with glo plug no ignition
Old 04-05-2007 | 10:02 AM
  #1197
AndyW
Default RE: gas fuel with glo plug no ignition
ORIGINAL: RysiuM
ORIGINAL: Ralphbf
I want to raise the compression, how much is enough?
I don't see anyone bringing the issue of the engine durability. To my understanding the original engine is designed for particular CR that creates given load on piston, connecting rod and crankshaft. Increasing CR I believe will increase the engine performance for sure, but at the same time it will increaso the load on these parts that may cause premature engine failure.
I wouldn't try to squeeze every bit if HP from "garden" engines - they are not designed for that. Something's gotta give. I would rather focus on the engine reliability running gas-glow plug combination. To increase the spped of flame you can use nitro, for detonation prevention - higher grade of fuel. For engine timing - the grade of glow plug. This is my understanding.
I have one thing to worry about tho. Did you guys experienced low lifetime of the glow plug running gasoline/oil only? Some time ago I run my engine on regular gas/oil mixture keeping the glow plug on the battery all the time, but the glow plug failed after about 20 minutes. Did I have bad luck or there is an issue there?
About garden variety, you're probably right. A hedge trimmer for an average summer will see maybe a half dozen light runs. But in the case of the Tanaka that I'm working with, it's from an industrial, portable drill meant to run all day, every day. The used one had a lot of wear and tear. Insdie there was a distinct ridge in the chrome at top and bottom where the ring stopped at each end of the stroke. The chrome on this engine is not a light deposit but is a measurably thick layer. I made up a hone to take out the ridges and now have a smooth, light, crosshatch.
I've read a number of referrrences that said not to leave your plug lit for too long once the engine starts. This is why, I guess, we add the stock glow fuel so that the plug can run without any amps applied.
