RE: gas fuel with glo plug no ignition
I run most of my engines on Gas/Glow now, though I do have some on regular ignition. With the Gas/Glow, (done properly), glow power is necessary only for starting, and I have had no problems with glow plug life. If one wants to use onboard glow heat, I would recommend a driver that turns the glow heat on at low throttle as you suggest.
AV8TOR
