RCU Forums - View Single Post - E-FLITE BLADE CP PRO
Old 04-06-2007 | 02:39 AM
  #1597
mrasmm
Default RE: E-FLITE BLADE CP PRO
That sounds like a real classic case of a worn out motor. If you have done 1 hour (4 flights?) per day since christmas, you're well above the trend. Normally motors only last 20 flight hours =). If you have done 4 flights per day since christmas, then your battery is probably also close to going out. They only last probably 200-300 cycles for the average user.
ORIGINAL: shadow flyer
i got a blade cp pro, and my motor is getting extreamly hot, evin with 2 heat sinks!! i thingk it's my battery wharing out, becaus i have flown about 1 hour a day since christmas, i was wondering if enyone had a secound opinion before i drop 30 bucks on a battert[:-] PLEASE reply back. thanks
