HI everyone,
Ok I have a problem with a Tx,
the Tx used to be throttle on the right stick,but I swapped around the parts to give me throttle on the left stick.
Now I have two problems,
1, The left stick seems to operate channel two on the Rx,no great problem,It's just I was told the motor should go on channel 1.
2, The other problem Is the throttle stick seems to work back to front,ie stick fully forward = no throttle and
stick pulled back toward the bottom of the Tx =increasing motor speed.
Surely this should be the other way around,ie push the stick forward to increase the motor speed.
The Tx I'm using Is an old fm one a futaba skysport 6A,not a computer type control.
I'm not to sure but I think It may have something to do with these dials and switches In the back of my Tx but I'm far to inexperienced to go randomly twidling things.
Thanks Paul.
