RCU Forums - View Single Post - What do you use ???
Old 04-06-2007 | 08:27 AM
MinnFlyer's Avatar
MinnFlyer
Default RE: What do you use ???
Like others have said, I use CA for most things - Mostly medium, Thin for hinges. And I don't use thin for much else
Epoxy where needed - and I only use 30-minute
Now as far as "wood" glue goes (Also known as Elmer's, Titebond, or Alphatic Resin) I only use it to save on the cost of CA in large areas.
For example: On a larger doubler, or a cap strip etc, I will usually use mostly wood glue, but instead of pinning, I will add a few dots of Meduim CA to hold it in place. That way I can continue to work while the wood glue dries.
