RE: Return line in perry pump
Omar,
The normal TNII carburettor can function on venturi suction alone (exhaust pressure is recommended).
...But since it came on an engine originally equipped with a high pressure fuel delivery system, maybe it is not a 'normal' TNII...
If you go through the check-list, you will find and overcome your problem.
In any case, with the Perry pump, you must never use exhaust pressure.
The tank's 'pressure' tube must remain vented to atmospheric pressure.
