RCU Forums - View Single Post - Propellar spun off gp-42 engine? Over-rev damage?
Old 04-06-2007 | 07:58 PM
bruce88123
Default RE: Propellar spun off gp-42 engine? Over-rev damage?
Do NOT use locktite under any circumstances on a prop nut.
Wood props compress easily and need re-tightening. I've never had that problem with MAS or APC props. Just don't use a 4-way "cross" wrench. Get yourself an 8 inch long box wrench of the correct size and you will be able to actually get them tight. Don't worry about damaging the crank or the prop nut by over-tightening it, you're NOT strong enough. No, that's not a challenge or an insult.
