RCU Forums - View Single Post - 2-stroke or 4-stroke???
Old 04-06-2007 | 09:24 PM
Dave McDonald
My Feedback: (19)
Default RE: 2-stroke or 4-stroke???
I would like to take this opportunity to discuss the charicteristics of a piped 2c. Doesn't putting a pipe on a 2c engine make the throttle transition sluggish?
A 2c with a properly setup tuned pipe won't be sluggish, but it will be more like having an "on-off" switch on the engine instead of a throttle. This is exacty why I don't use tuned pipes on 3D planes.
But don't confuse a tuned pipe with a Mousse Can Pipe. They are not the same thing.
.....a 4c has better over all transition authority? Isn't that what 3D planes need?
I agree that 3D planes need an engine with very good transition characteristics, but I don't agree that a 4c does it better. A 2c with a MCP will run and throttle as good or better than any 4c.
Not the blistering high speed's & horse power sluggishly built up from the supercharged effect of a pipe on a 2c, but the torque available at any position of the left stick that 4c's offer? I could be wrong here because alot of people use the piped 2c engine......
When it comes to 3D flying with a 2c, a tuned pipe is your worst nightmare.
But a Mousse Can Pipe is a 3D pilot's dream come true! A MCP can give nearly the same power boost as a tuned pipe, but without the annoying "on-off" syndrome. A properly setup MCP on a 2c will have a very linear and instantaneous feel on the throttle stick......almost like an electric motor.
Here's a link to a video of one of my planes. The engine is an old OS 40 FSR with a MCP spinning an APC 11x4. Crank up the volume and listen to how the engine instantly responds to even the slightest changes in the throttle stick.
http://the******************.com/~vi...ddd_video1.wmv
Even the 40 LA will respond very well to a MCP, but the TT 42 GP just does it much better......especially for 3D and sport flying with one of the old Stickit type planes.
