RE: RCM Eagle V
Are you going to build one?
HINT: order a version V from Precision cut kits, then you will have the version V wings and can build the version 7 wings and use then unterchanbeably, also you will have most of the fuse parts except for the forward section that is longer on the 7, the longer nose is a MUST to get proper balance
Fie Bao makes an almost 100% ARF version of the Version V, check the Digitecturbines website
