nice looking plane you got there. you need a test pilot?
i have not done that method yet myself on a plane with dope but have done similar stuff in the past using the paper stencil thing. once cut out spray with 3M-77 adhesive. a light coat will do. sticks good and lifts off easily. done right you should have no problems. hope this helps. there is probably other brands out there but this is what i use.
