CA Hinging with Covering and ARF Controls Improvement
4. Sand a 45 deg bevel on both side of each surface. Rounding is ok as well.
5. Refit the CA Hinges in place and insert a T Pin through the Hinges as
alignment and equal distance can be maintained throught the surface.
Remove the Pins and apply thin CA approx 2-3 drops to each let it saturate
wait about 10 sec and do it again. Let Dry about 5 Min and touch sand
the surface to remove any high points caused by the CA.
