CA Hinging with Covering and ARF Controls Improvement
6. Now take your covering starting at the leading edge seal normally
as you would a wing, stab etc. But stop at the 45 degree bevel and
seal the first edge. Taking your Iron seal the inside of the bevel
all the way to the hinges. Repeat backawards while maintaining a down
force opening the hinge point. This will now give you a Sealed hinge area.
