RCU Forums - View Single Post - CA Hinging with Covering and ARF Controls Improvement
Old 02-18-2002 | 03:38 AM
Scorpionjack's Avatar
Scorpionjack
Default CA Hinging with Covering and ARF Controls Improvement
7. Finish sealing the rest of the surface and check for deflection.
Deflection should be nearly 90 Deg.
8. Your Now finished with the hinge and you have accomplished a Clean
Surface and basically a Double hinge enviroment. If the Hinge broke you
would never know it as your control surface/ covering is also a hinge.
9. Other benefits is your aircrafts controls will be alot more responsive
as there is no airgaps.
