RE: Eagle 50?
The Eagle 50 is a nice helicopter, however you may have better luck with a blade cp since in has the same size motor and, for the most part, parts. The difference is the size, the blade cp is lighter, therefore it is more maneuverable, and has better climb performance. I have had problems with the eagle 50s electronics and the motors have died after a couple of hours. The blade cp may cost slightly more, but in the end you will spend less since you will not have to buy replacement parts due to the poor quality, motors and electronics.
