RCU Forums - View Single Post - Bad Glow Plug Starter? Can't start engine
Old 02-19-2003 | 12:07 AM
flap
Default Bad Glow Plug Starter? Can't start engine
You said it "didnt get warm"??
Did you remove the plug and install it in the starter? It should glow if its working.
How did you get the fuel in the tank? Should be able to turn the crank in the opposite direction to remove it or reverse the swithch on an electric pump.
