RCU Forums - View Single Post - Bad Glow Plug Starter? Can't start engine
Old 02-19-2003 | 12:23 AM
paul_c
Default Bad Glow Plug Starter? Can't start engine
Originally posted by flap
You said it "didnt get warm"??
Did you remove the plug and install it in the starter? It should glow if its working.
How did you get the fuel in the tank? Should be able to turn the crank in the opposite direction to remove it or reverse the swithch on an electric pump.
I'm not really worried about fuel in the tank, just that the engine was primed, and now the fuel is going to sit there.
You said I should try unscrewing the plug, and put it in the glow plug starter? If nothing happens (i.e. plug doesn't glow), how will I know if it is the starter or the plug itself?
