RCU Forums - View Single Post - Bad Glow Plug Starter? Can't start engine
Old 02-19-2003 | 02:48 AM
paul_c
Default Re: Hmmm..
Originally posted by Kevlar
If I may add and re-iterate here are some simple steps to isolate the problem
• Remove the plug, install into the heater/charger. Does it glow?
o If so, your engine might be flooded.
 If so, open the throttle and turn the plane upside down.
 Flip the prop and let that fuel pour out.
• If the plug does not glow, check the voltage of your heater/charger.
o Doesn’t matter if you get 1.2 volts as there is no current draw and you could be low on overall amperage.
o Charge it for about ½ hour. Won’t hurt it if it’s already fully charged.
• If you have a VOM (Volt Ohm Meter), check the resistance of the plug. Do you get a closed circuit reading?
o If you don’t have a VOM, get yourself a battery, a bulb, and some alligator clips (or wire).
o Run one from the battery positive to the bulb base, bulb nipple to the plug tip and battery negative to the plug base. (see pic)
It should light, if not, you have a bad plug. Just make sure you have enough power for the bulb. Easy way to test, don't add the plug into the equation, and don't exceed 3 volts!
KEVLAR, YOU ARE SOMETHING ELSE. Thanks for addressing my problem as if it was your own. I'll let you all know how things turn out in the morning.
Paul
