RE: Dual Channel Crystal and Receiver Question
You mean Dual conversion, not dual channel. Just order the channel 50 crystal that goes into that receiver, and it will work great (assuming that it is a negative shift receiver, or (at least) a shift selectable). If it is shift selectable, then you will have to change the shift to negative shift before it will work. Do not change the crystal in your radio--it has nothing to do with the crystal in the receiver (as long as they are both on the same frequency). Dual conversion only deals with the way the rx receives and decodes the signal--it has nothing to do with the transmitter.
