RCU Forums - View Single Post - Engine weight and reducing it
Old 04-08-2007 | 03:20 PM
Rcpilot's Avatar
Rcpilot
My Feedback: (78)
Default RE: Engine weight and reducing it
I'm no expert in metalurgy (sp?), but isn't titanium brittle? I might be wrong, but I've heard people say not to use the titanium axles because they are brittle. I would think you wouldn't want a brittle crankshaft or rod.
If titanium is brittle, then you wouldn't want to use it for prop hub bolts. Your not supposed to use stainless for prop hub bolts and firewalls because it's too brittle.
Why not make a CF crankcase with sleeve inserts where bearings must be pressed in? Or whatever? I would think a CF crankcase would be fairly light.
Most of the current magnesium cases are cast. I've seen quite a few on conversion engines. I really couldn't tell you what current production engines had magnesium cases. It's been said that a cast magnesium case is lighter than a cast aluminum case. AND it's been said that a machined aluminum case could be as light as a cast magnesium case. So, it stands to reason, with me, that a cast case is heavier than a machined case. Why not machine a case from magnesium? Wouldn't that be light? I have no idea what it would cost. I'll bet that as soon as the magnesium wholesalers figure out there is a demand for it--the price will go up. We probably have a surplus of it on hand right now and they can't give it away, but soon as they find out they can make a buck--they'll be making 100 bucks for it instead. Speculation...
I think that it would be neat to see someone come up with an engine thats really ahead of it's time and innovative. Something that will have all of us going [X(]
I'll gaurantee ya something right now--and I'll stand by this untill I'm either proven right or end up with egg on my face.
It's gonna be EXPENSIVE
