RCU Forums - View Single Post - BCPP wiring???? help
Old 04-08-2007 | 04:03 PM
itsjojo
Default RE: BCPP wiring???? help
Hi I am just going over my cpp and going to help you out.
Yes your servo configuration is correct 1 2 3 4 5 6 They are all correct as you have witten them.
Chanel 5 on the reciever ( the g90 gyro control is plugged into channel 5 (as you mentioned) This is a yellow wire which is forward as well Inline or under all the orange wires on the forward side of the reciever sockets.
At the gyro top prong orange, middle red, and bottom black.<<<<<<<<<Yes to all this too. Mine is set up this way and running fine. (This wire has a tag on it indicating "rudder ch4 and comes from the 3n1, the other wire goes to ch 3 on the reciever and should have a label on it saying "throttle ch3"
I've turned my proportional to 0. <<<< Yes this is accurate too.
I am new to the cp pro. I am actually running a CP with a full CPPro radio system from ebay. I have just installed the g90 gyro and love it. Based on your tests, it really looks like you may have burned up the radio gear in the heli. Ihave bought a few cp's from ebay and this is a common occurance
Good luck and I hope your flying soon.
Jojo
