RCU Forums - View Single Post - OS Wankel Overheating
Old 04-09-2007 | 10:01 AM
Bax
Default RE: OS Wankel Overheating
Sagging may be caused by an engine that was never fully broken-in, or has had buildup over time that is causing friction. You may want to try some extended running at very rich settings to see if it just needs more running time. If it's the original-series engine, are you running it with the shroud that came with it, and is it getting enough cooling airflow?
