ORIGINAL: Roger M
I was in Motors and Rotors this morning, and they have 2 Flash kits for sale. What are peoples' views of this model, which I would power with a P80?
Roger
Check out the write-up in the current issue of JetPower. I think it will fly fine on the 80. A friend has a 120 in his and it is a spectacular performer with this engine. Weight will likely be between 24-25 pounds dry, so a P80 will give you a little less than 1 to 1 and a 120 will be slightly better. Do get the optional wing fuel tank in either case.
