RCU Forums - View Single Post - CX2 FLIGHT TIME FIXED!
Old 04-10-2007 | 01:28 AM
blade_killer
Default RE: CX2 FLIGHT TIME FIXED!
ORIGINAL: Patrick9699
Okay, new 4 in 1 is installed.
First off, the red light does NOT come on until the throttle is nearly buried....
Now, we have a new set of symptoms to review:
Helicopter lifts off and begins to pirhouette hard to the right. Full left rudder almost makes it stop, but it still drifts nose right.... This is a new symptom.
Also, with the rudder buried to the left, the helicopter will not maintain altitude, and settles gently down to the ground...
With the rudder allowed to center, helicopter climbs briskly and seems to have plenty of power... climbs strongly while spinning...
When left rudder is re-applied, helicopter almost stops spinning, hovers for a couple seconds, and then gently descends to the ground.
Any ideas????
just a guess but for your spinning issue, sounds like the proprtional pot needs adjustment (it is a new 4-in-1 right?) remember to unplug the battery before making the adjustment.
when you turn to fast to the left it is normal for the CX to slowly lose altitude, try turning left a lot slower and see if it drops...
hope I'm not telling you anything you already know and some of it helps ya
