Need opinions for new combat plane
You might want to check out the HOR by the SPAD folks. They use .15's on it, but I fly them with .25's and even a .46. They are a snap to build too. Instead of the coro wing, I use a 64" foam wing, but the coro wing should be fine. just that the 64" has more cutting area. Also the foam wing will be stronger.
