ORIGINAL: combatpigg
I've wondered how to handle the bubble free tank with a cowl and I hope that fueler valve turns out to be the answer.
The tank sits low in the fuse and the pipe runs straight back. The opening has to be cut to suit the tank you are using. A plywood tray is provided for tank mounting if needed. The servo pocket is precut. but due to the length of the Jett Bubbless tank used I had to move my throttle servo forward.
bob
