RCU Forums - View Single Post - pull-pull soldering
Old 02-24-2003 | 01:40 AM
big max 1935
My Feedback: (9)
Default pull-pull soldering
Some where back in the dark reaches of my mind,some thing tells me that soldering control cable is not the thing to do. Think that vibration would break them where the solder has wicked up the wire. Full sized A/C cables are swagged on. Think that a threaded rod with a hole cross drilled & the cable looped through it & into a copper or brass sleeve crimped on the wires would be better . Du Bro makes such one, looks like a better deal to me. What do you think?>>>>>>>>>>>>big max 1935>>>>>>>>
