RCU Forums - View Single Post - Protecting Electronics
Old 02-21-2003 | 01:34 PM
Malorie
Default Protecting Electronics
Don't complicate the system.
Wrapping the plug wire could increase a problem, if there is one. You are much better off keeping things simple. Plenty of folks out there are running without a shielded plug wire without a problem.
The whip antenna is a good idea if you are carefull to install it properly per the instructions. It allows you to keep the antenna away from the ignition.
