On the crank pin, Did you run it and have it go bad? Is that how you know that the pin will not hold up?
By the looks and sound of it, It looks as if you are going to have a grate engine when you get it all worked out.
I started to do one some time a go but did not get it done. I got the rod done with berrings in it but did nothing to the pin or the crank pin..
I was not sure it was going to work. Seeing what you did I just mite start working on it. That is if I can get all the othere thing I got going on done
Paul
