RCU Forums - View Single Post - U-Can-Do 3d 46?
Old 04-11-2007 | 03:52 PM
  #5900
gunfighterII's Avatar
gunfighterII
Default RE: U-Can-Do 3d 46?
Adrian's,
Sounds to me like you have poorly built ailerons or a bad servo with excessive gear play. check your aileron for stiffness or as a last resort, remove covering and sheet the aileron.
Seal the gaps, even though your hinge line is tight, those are big surfaces to move.
A 12-4 should be perfect for that engine, what kind of rpm's are you getting?
