RCU Forums - View Single Post - Engine Question
Old 04-11-2007 | 06:07 PM
bigedmustafa's Avatar
bigedmustafa
Default RE: Engine Question
ORIGINAL: MinnFlyer
ORIGINAL: Betelguese
If the throttle closes all the way won't it stop the flow of fuel into the carb causing the engine to stop.
Only on a good engine
It's a Thunder Tiger engine, MinnFlyer, so you know it's a good engine!
That little sliver of open carb at idle is normal. If it were closed completely, then the engine couldn't idle after being started on the ground. For a standard radio without a throttle kill setting, this slight opening should be present at minimum throttle but closable by turning the throttle trim all the way down. This will allow you to turn off the engine from the radio.
