RCU Forums - View Single Post - Cotrol surface "Jumpy?"
Old 02-19-2003 | 11:16 PM
SAL98's Avatar
SAL98
Default Cotrol surface "Jumpy?"
Definitely, For 3d rates you loose alot of the servos resolution due to the amount of surface deflection (roughly 40 to 50 degrees)
So expo helps keep the speed down around center even in low rates. This is why digital servos feel smoother, they have much higher resolution to begin with (more steps per degree of movement).
