dynamite compression guage
I picked up a compression guage. I know that the best way to use it is to take the reading when the engine is new and then take it periodically and if the pressure starts to drop, you need a rebuild.
But, what about if you bought the engine used and there is no base reading. What psi would be the norm? I just bought a used engine and the reading was 30psi. Does that sound normal?
