RCU Forums - View Single Post - Do sizes of gloplugs make any difference?
Old 04-11-2007 | 07:21 PM
bruce88123
Default RE: Do sizes of gloplugs make any difference?
ORIGINAL: armody
Hi there all,
I was just wondering that there are assorted glo plugs available, some have long heads, some have short heads, some have open filaments, some have a metal strip on the top of filament crossing from one end to another. My question is, if a gloplug has long head does it make any difference in any engine or short head one would work better? Gloplugs can be used for any engine either 2 stroke or 4 stroke and whatever the engine displacements are? or recommended or some particular gloplugs should be used.
Mody
"long" plugs have longer threaded portions and if used where a "short" plug is required COULD actually hit the piston. If a "short" is used where a "long" is required it may not get down into the combustion area. The "strip" accross the plug is called an "idle bar" and is used to keep cold fuel from splashing on the element and cooling it too much and making it stop firing the mixture.
Always use the proper length as recommended by the manufacturer. The use if an idle bar is kind of option al in most modern engines although they are use more often in side mounted or inverted engines.
