RCU Forums - View Single Post - Building from plans
Old 02-20-2003 | 12:23 AM
CafeenMan
Default Building from plans
I use spray glue to attach patterns to the wood and after they are cut out, peel off the pattern. If you make copies of the patterns from the plans, be sure that the copier made them the right size. Many copiers don't copy at exactly 100%, so be sure to check.
