RCU Forums - View Single Post - How to set different throws for Elevator and Aileron in an elevon flying wing
Old 04-12-2007 | 05:34 AM
Hagar69
Default RE: How to set different throws for Elevator and Aileron in an elevon flying wing
End points should be set for the maximum throw that you want on the servos. Then adjust dual rates for elevator and aileron to the desired settings.
End points changes the servos, dual rates changes the commanded range when moving the sticks.
Hagar
