Need help setting up servos for elevator
Hi all,
I just got a goldberg 67" edge540 as a third plane and need some help setting up the servos for the elevator. The instructions require two servos mounted inside the plane connected by pushrods to each half of the elevator. The problem is that when i use a y-harness to connect the two servos to the reciever, the servos move in opposite directions therefore the two halves of the elevator also move in opposite directions. But this is the way the instructions has described to install the servos and pushrods. So how do I reverse only one servo and not the other that are connected by a y-harness to the reciever? I don't think I can do this from my computer radio or can I?
Graham
