RCU Forums - View Single Post - Does a fully Synthesized Tx work with a crystal fitted Rx?
Old 04-12-2007 | 08:36 AM
bruce88123
Default RE: Does a fully Synthesized Tx work with a crystal fitted Rx?
ORIGINAL: MikeL
ZPCM and SPCM are just two different types of PCM encoding. ZPCM is the older type, with 512 steps of resolution. SPCM is the newer type, with 1,024 steps of resolution. You set the transmitter to the type of PCM that your PCM receiver is designed for.
That's what you do IF you have a transmitter with selection capability.
