RCU Forums - View Single Post - CA Hinges
Thread: CA Hinges
Old 04-12-2007 | 01:30 PM
G17Staggerwing
My Feedback: (159)
Default RE: CA Hinges
I use the same method as Bread. I mark the position in the center of all locations then I use a number 11 Exacto knife blade and make multiple cuts, going deeper with each pass. Make the cut a little longer then the hinge you are using and then you will have room to work the hinge into place. Once in place lay a bead of thin CA on both sides and let it dry, WHALA your done!!
Nevin
G17Staggerwing
