RCU Forums - View Single Post - Best way to remove prop driver?
Old 04-12-2007 | 03:28 PM
w8ye's Avatar
w8ye
My Feedback: (16)
Default RE: Best way to remove prop driver?
That grease will come out of the bearings anyway when you run the engine and the model airplane fuel gets in the engine.
If you take a seal out of the bearing, it is unlikely you will be able to reinstall the seal back into the bearing so be sure you do not remove the outside of the front bearing.
