RCU Forums - View Single Post - 2-stroke or 4-stroke???
Old 04-12-2007 | 08:18 PM
  #43
Dave McDonald
My Feedback: (19)
Default RE: 2-stroke or 4-stroke???
I've had two Stickit IV planes. I built the first one that you see in the avatar, the second one I bought used.
The first one had the servo arms hidden inside, the second one had the servo arms exposed. I highly recommend going with the exposed servo arms because it makes the linkage setup a lot easier.
Both planes used a 1/16" music wire pushrod on the elevator with two small equally spaced nylon guide tubes to keep the pushrod from bowing.
Both planes also used a pull-pull cable for the rudder. The first used two small guide tubes for the cable, the second used only a single guide for the cable. The single guide worked just fine.
I ran a 4 ounce tank on my Stickit, which is the size I'd recommend for sport flying.
