RE: Cowling halves
i would use the bondo if gaps are wide and epoxey if they are only under 1/16.bondo is easy to work.you will need to sand the plastic rough either way you choose to get the bondo/epoxey to adhere good.if you use bondo wet sand like was said here it that makes it nice and slick
