ORIGINAL: cybertech
When you get a plane with blueprints do you actually have to cut and make everythig yourself?
That depends. If you are truely building from plans then yes you have to cut everything yourself. But if you are building a kit then the parts are already cut for you. True builders plans and kit plans differ in that the kit plans usually don't have the outline of the crucial parts in them. Builders plans will have the outline of every part for the plane, and you have to cut that part yourself
Ken
